Warren's second display unit on the same basic unit is an easy logical solution, providing you don't want two diffeent types of units.
Hee's an edited set of posts from another recent thread:
Posted: Sun Mar 09, 2008 2:37 pm
I've been told that running multiple transducers won't work due to signal interference between the units. Is this not the case? I have thought about adding a second 'ducer, but was concerned that it wouldn't work.
-Rod
flrockytop wrote:
My cd19 had a Lowrance on it when I bought it. I added a Navman. Both are 50/200 machines. The Lowrance transducer is mounted on the stern I first tried shooting the Navman transducer through the hull. This did not work so well. When running both on 200, the signal from the Lowrance would sometimes overpower the Navman so much that it would not pick up at all. If I turned on the Navman first then, usually, they would both work. Even then I would pickup some sawtooth interference lines in the Navman display. I could run one on 50 the other on 200 and they would work. I moved the Navman transducer to the stern on the other side of the motor (about 2 feet apart). At this location they both will work.
I have used two at the same time on other boats with similar results.
Sometimes they will work and sometimes they won't. When widely spaced in shoal water, they will work OK. If the transducers/sounders are significantly different frequency, they will work.
If they are both the same frequency and close together, they will probably not work.
Unfortunately almost all of the fathometers use 200 mhz transducers currently. There used to be 215, 192, 200 etc...There is a Garmin at 235 (I belive)--but it will cost $500 with the head and transducer.
Bob
Full text
HERE
Joe: :teeth :thup
