dielectric grease
C-Wolfe
Active member
Sep 16, 2020
422
36
Location
Anchorage
2008
255 Tomcat
Callisto
Im about to replace my battery switches and realize there is a good amount of corrosion on most crimp connector, look like the wrong tool was use and damage the heat shrink tubing and allowed moisture to do its thing. So now I feel like I should replace all wire that are most expose to the elements, so basically everything from battery to main fuse box inside cabin. I really like the adhesive line heat shrink tubing, I have also used dielectric grease on several occasion but never together. Will it compromise the glue and negate its use or is it possible to use both? So what are you all thinking is the best approach for the longest lasting connection? Thanks for all input.
Crimp lug to wire, then shrink tube(with the glue lining) then dielectric grease the lug and stud. :thup
I coat the terminals at the Batt. with Corrosion X. I clean the terminals out of guilt every 2 yrs, never any green stuff :thup
There is a marine electrical store on the E. side of the new seward just N. of dimond (CRS wont allow me to recall the name) they have Marine wire & decent prices & every thing you will need.
tsturm, I sent you a PM, let me know if you receive it, it look like it is stuck in my outbox and I’m not sure why.
C-Wolfe":zur8sxzs said:
. . .I sent you a PM, let me know if you receive it, it look like it is stuck in my outbox and I’m not sure why.
That's just a feature of the PM system. Until the intended recipient actually clicks on the message, it will remain in your "outbox." Once the recipient looks at the message, it shows up in your "sentbox."
On the larger question, agree completely with tsturm. Just don't put the dielectric on the terminal before you make the connection. A dielectric between the points of contact will interfere with current. I don't know if the dielectric could possibly compromise the heat shrink adhesive. We must have some chemistry geeks around here to answer that.
