C-Nile":3lvc1pz3 said:BrentB":3lvc1pz3 said:How is the sole attached to the hull?
Brent,
A picture is worth a thousand words. Please click on the below link
http://www.c-brats.com/modules.php?set_ ... _album.php
C-Nile
Perfect thanks a million
Brent,
thataway":soijch60 said:Rich,
My apology about the name-yes, I was addressing you.
You posted "Do you know that in the Northeast, there are no cost effective alternatives to the C-Dory line or Marinaut?"
You don't shop for boats just at boat shows. You research the various publications, look at used boats, do internet research, and often depend on people who have more experience than you. I am very glad you have a boat which works for you--it would not work for us, for a number of reasons.
To address your quote--and challenge that there are no other satisfactory pilot house boats on the East Coast.
There are multiple small builders who build on the down east, Sea Skiff, and similar type hulls. There are also larger builders such as Rosebrough (currently built in the USA) along with SeaWay and Eastern, Parker is extremely popular on the East Coast, Shamrock (mostly inboards), MayCraft, Steiger, and Atlas/Acadia come to mind off hand. of boats available, also some of the Nimble/Kodak type of boats meet these criteria. (and a bunch of others, which have a different hull forum--like the Adventure craft etc).
Jake":1tya5cry said:Of course you do have a choice with the Marinaut, Les would be happy to modify the 215 and add hatches and storage, it's the customers choice if they desire to forgo the sealed air space between the sole and the hull by adding storage. I'm not sure why they weren't molded into the sole mold in the first place. Seems like you could mold in the storage and retain the air thight space.
Jake
starcrafttom":3sdjfwm9 said:boy I would like to hear from the builder on this one.
chimoii":1rl94kpo said:In the end I bought a C-D Venture 23. It is not unsinkable but does have some foam in the hull. That makes it heavier and less fuel efficient than a 22. Maybe it also means it rides better.
Sunbeam":2omgf445 said:I don't mean for this "nitpick" to take away from your main point, which was that all boats are compromises and one needs to choose the best set (of compromises) for ones uses and taste. I agree whole-heartedly with that point.
chimoii":2omgf445 said:In the end I bought a C-D Venture 23. It is not unsinkable but does have some foam in the hull. That makes it heavier and less fuel efficient than a 22. Maybe it also means it rides better.
But... I don't see where a foam-cored hull would be noticeably heavier than a balsa-cored one, all else being equal; so that makes me think it's something else (other than foam core) about the Venture 23 that makes it heavier (and probably hull design that makes it ride better - looks like it's an "evolved" hull design as compared to the 22 Cruiser).
NORO LIM":3mbspciz said:See post above. The CD has a cored fiberglass sandwich hull. That's it. The Venture has the same kind of hull, but it also has an additional sole with foam between the sole and the hull. That's not the only reason it's a little heavier, but it is one.
Sunbeam":314k4qat said:. .
But how is that really different from the post ~2006 C-Dory 22 Cruisers, which all have a permanent/flat cockpit sole which is a fiberglass/core/fiberglass sandwich? . . .
Will-C":3h1v5knv said:I think the main weight differences are that the foam weighs more than the balsa core,
D.D.
journey on":386wfoy2 said:The purpose of the spacing between the two hull layers is to provide beam strength. It doesn't matter what the material between the hulls is for structural reasons. The lighter the better, because it doesn't offer strength, just spacing and vibration damping.
