smckean (Tosca)
- Joined
- Jan 18, 2014
- Messages
- 974
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Tosca
I read that....and I wondered. I have a Scotty base with my Brutus; and indeed I did break it once (thankfully I did have a lanyard attached to it, so I didn't lose the puller). However, it broke because the trap was hung up on the bottom, and the boat was in a decent current. Basically the trap was an anchor attached to the boat via the Brutus. At the time, when I saw the puller under strain, I just thought there was a lot of drag on the deep pot. Then suddenly POP!.....the plastic Scotty mount broke in half and the puller went over the side. Eventually I figured out the pot was stuck on the bottom; I released it by backing over the pot location and pulling it in the opposite direction as the current flow. I spent the next 2 hours pulling up the pot on a 400' line by hand (not easy for a guy in his 70s single handing :wink:I read about a Scotty base breaking off with his pot puller attached.......have a leash attached from your puller to a cleat or something solid that’s easy to cut free if needed.
I have not had any other trouble with the Scotty mount, and I've had some powerful pulls including another couple of stuck pots (but now I recognize the situation). So I question the speculation that the Scotty mount is poorly designed.
