A
Anonymous
Guest
I have always been plagued by the non flat floor in our 25 ftr. Well now that she's wrapped up for winter it's time to create the "dream" short list and that floor is on top of the list.
Loctite makes a number of concrete and flooring products that have some appeal. I'm looking at a self leveling epoxy grout for a foundation before a teak or other suitable top is put down. It looks like the deepest part of the valley will require 2 inches of fill in the area adjoining the v-berth then tapering to under a 1/2 inch at the back door. This can be accomplished with about 7 gallons of grout.
Once upon a time I owned a 1950 1 ton Dodge truck and to say the suspension was stout would be an understatement, it was non existent! This problem was easily remedied by pouring an inch of cement in the floor of the truck bed. The ride softened up and handling was improved as well.
Now I realize there is a lot of difference between the truck and the boat but I have another idea that may get incorporated into this project next spring. I have an endless supply of scrap Tungsten Carbide available to me and for those of you not familiar with it, this stuff is considerably heavier than lead. It would be a simple matter to add a couple hundred pounds right down the center before pouring the grout which would easily keep everything in place. Im thinking an evenly distributed, centrally located weight at the lowest possible point in the boat "May" have some dampening effect on the boats ride. It "May" even function like a ballasted keel, which wouldn't be all bad either.
As usual, any constructive input is appreciated.
Mike
Mike
