I want to mount a Garelick style motor mount for a 6 hp kicker on my 22. I know it is highly suggested to enlarge the holes, fill with epoxy, and re-drill. Despite my extensive searching through the archives, I haven't found the specific technique on how to accomplish this task. From what I have surmised; the reason to do this is to prevent the balsa core sandwiched between the inner and outer fiberglass walls of the transom to "squish" or deform and to give a much more solid mount.
However, I haven't figured out the actual mechanics on how this is done, and what in the recommended enlargement for let's say 5/16" mounting bolts. I've read reference to using a Dremel tool, but not which bit or attachment to use. I've even read something about chucking an Allen key in a drill motor and auger out the balsa core between the fiberglass walls. Seems a little crude, and how much oversize to make the inner hole?
Also, when filling the enlarged holes, it baffles me on how to ensure proper filing of the horizontal holes even with thickened epoxy and to prevent air pockets in the upper cavity of the holes. Certainly one would tape up both sides the holes when curing, but what stops air pockets from forming?
I'm pretty handy, but am a little confused in the technique. Seems like an important process and I certainly don't want to screw it up. Thanks in advance for any suggestions.
- Steve
- Steve
