Saxe Point
thataway":2xhaw8lw said:Saxe Point":2xhaw8lw said:As I understand the "priority scanning" function, if you set channel 16 as a priority channel, you will absolutely never miss a call on channel 16. Even if it is somehow possible, I think the possibility is a theoretical rather than practical one. I've only used one radio, with channel 16 as a priority channel. I don't think I have ever missed a channel 16 call that was within range of my radio. Again, I'm just not sure it's even a theoretical possibility.
An example: A narrow stretch of the ICW is called "The Rock pile" Any vessel which is entering this stretch should give a "security" call on Channel 16 and Channel 13. (Channel 13 is the commercial traffic--tug to tug channel for the ICW--other areas will have different traffic scheme traffic. There are many areas like this.
I was Southbound, had a single radio, and called "security" on Channel 16, and then on 13. Exactly at the same time, a tug and tow, was North bound, and they gave a 'Security" on 13 and 16--at the same time I was transmitting. Thus neither of us knew that there was opposing traffic. If I had a second radio, I could have avoided, having to back a 62 foot ketch a few hundred yards, and then put her up against the bank, as the tug and tow went by on a slow bell--with a couple of feet clearance between the barge and my vessel.
There are many other instances, where you may be on the radio; for example on 68 talking to a friend--and there is a "mayday" on 16. You will miss that.
Even if you were just monitoring--with priority 16, you may have missed a key part of the transmission by the time the radio dropped the call it was on, and moved to 16.
Good points. My experience is altogether different in that I never boat in that kind of proximity to other boats, let alone commercial traffic. Nor is there that much boat traffic up here, compared to other places. There's a fair bit of commercial, recreational and other traffic, but lots of room for everyone. In your conditions, it sounds like there's a lot more stuff going on.
Where I boat: http://www.ourbc.com/bc_maps/the_island ... e_fuca.htm
