Chris, yes, Bombardier is a Canadian company, and yes the Evinrude E-TEC's are engineered and built in Wisconsin. Even if folks are wary, that's at least a reason to root for their success.
For those who haven't read the white paper, and may wonder what the answer was to your concern about damage to the engine from too lean a mixture, here is the explanation. I agree, it's pretty amazing:
"Speed Adjusting Failsafe Electronics (S.A.F.E.) is also incorporated to ensure that if an engine life-threatening fault should develop (like overheating or no oil pressure), the rpm is reduced to 1200 maximum, an audible alarm is sounded and a warning light is displayed on the dash. At this speed the engine requires almost no cooling or lubrication system functions. Tests have shown an engine can be run all day at 1200 rpm with only the oil inside the crankcase when it was started. New shutdown modes are also incorporated. If the engine cooling system or EMM temperatures continue to rise, even after activating S.A.F.E, the EMM will shut down the engine before permanent damage is done. Once temperatures have reduced the engine can be restarted."
As for the question about white lightning, those cheesehead engineers in Wisconsin just scratched their heads. Only a southern boy would know about that, they figure. :wink:
Chuck
