Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,821
- Reaction score
- 181
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
When single handing, cockpit controls would make it possible to get to the pilings with reasonable control. Other wise it would be difficult in the C Dory when single handing.
Every marina is different, At Panama City we go bow in. Getting out of the cockpit at any marina, especially with high docks is much easier if you open the zipper at the back of the cabin house, and put in an extra hand railing, on the outboard aft edge of the cabin top, which gives you something to grab onto as you come out of the cockpit. Note the second extra hand rail forward also..
When you have to use this type of set up on a regular basis, you adapt and learn the techniques. It certainly is intimidating for the first few times.
Backing with a single engine is a technique learned. Same as backing in single screw inboard boats--there may be times when you give a short burst in forward to kick the stern around. The only twin outboard boat I have owned was the Tom Cat--and it backed very well--but the hulls are like a keel and the motors are widely set apart. I am sure that twin outboards would be slightly better moving the stern, But not as good as twin inboards.
