blackfish-
I don't have one, but remember the discussion you're talking about.
Most all the owners of the fan were very favorablly impressed and satisfied with it.
Most folks were using the eco fan to aid in circulation of their Wallas stove. They preferred it's quiet operation, and set the fan on top of the Wallas stove's cooking surface.
Wherever you use it, it has to be setting on a hot surface, as it works by conducting heat from it's foot up to the radiation/cooling fins behind the fan blades and generating electricity to turn the blades in the process.
As I remember, some of the Brats with the fan had the two blade model, and some owned the three blade one.
Moose/Al was one of the folks who had one and was very happy with it. If he doesn't see this thread, send him a PM and ask him about it.
For those who are wondering about this fan, here's a
LINK to one supplier.
Joe. :teeth :thup
Model 800 (left) and 802
More Information:
This unique freestanding heat-powered fan is designed to improve the efficiency of a wood stove by circulating the warm air produced by the stove. When placed on top of a heated surface, the Ecofan generates its own electricity. Temperatures of operation range from 150 degrees to 700 degrees Farenheit. The Ecofan does not use any batteries or external electrical connections.
The fan has a thermoelectric module which acts as a small generator to power the fan's motor. When this generator module experiences a heat differential between its top and bottom surfaces, it creates electricity. The bottom surface of the module is heated by the wood stove, while the top of the module is kept cool by the fan's top cooling fins. The speed of the fan varies with the stovetop temperature; on average, Ecofan Model 800 circulates 100 cubic feet of air per minute, while Ecofan Model 802 circulates 150 cubic feet of air per minute.
