Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 9
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Short question:
How many of you have 90º elbow fittings coming off the Racor filter, and do you have any fuel starvation problems?
Background:
I'm trying to decide where to mount my Racor fuel/water separator. Originally the boat had a large/crusty Racor on the inside of the transom above the sump, but I have tossed that filter and filled those holes, so I have a clean slate.
That same, under-splashwell location would be nice for hose routing, but I'm a bit concerned about spilling fuel into that area when servicing the filter, and/or hitting it with stuff I toss under there.
So, the outside splashwell location is looking good :thup I think I can make a small cover for it to reduce corrosion. The remaining decision points are exact location and hose routing. I looked at as many photos as I could find in the albums - there is quite a variety of locations. I mean, they are all in the same general area, but some are above the boot, some beside it, some more aft or forward.... I wonder which is best since I have a clean slate?
I originally ordered straight fittings to lead the hoses into the Racor, but in the splashwell it looks like that would make for some big, messy hose loops. I saw that many of the filters in the album photos had 90º elbows coming off them and that made for very tidy hose routing. I thought I had read that was a bad idea, but it looks like a lot of people use them and are apparently putting along just fine. I can't find what my Yamaha "drinks" per hour in the manual, and the elbow people were not able to really help with a flow rate reduction (just the diameter inside the elbow). I'm sure a physics person could figure this out, but on the other hand, as long as I know that many of you have the elbow fittings and no problems, that seems like it should be good enough? I would really like to get the fittings ordered and decide on an exact location for the filter.
My 22 has an 80hp Yamaha and an 8hp Honda. Both will run through the filter (but not at the same time).
BTW, I have read all the old threads on this, but didn't find too much specifically about elbows or exactly where on the splashwell (I did find lots of basics about splashwell vs. inside transom, which was good reading).
Thanks!
Sunbeam :hot
Background:
Thanks!
Sunbeam :hot
