Tug
Active member
- Joined
- Jun 22, 2007
- Messages
- 1,003
- Reaction score
- 6
- C Dory Year
- 1985
- C Dory Model
- 22 Angler
- Hull Identification Number
- DOR22241H585
- Vessel Name
- Drifter
I will try to phrase this question as clearly as i can...i am not electrical minded.I have just resently discovered what a bus is..i think.
I removed my old GPS..Fishfinder and Loran from my boat...i removed the speedometer wheel and transducer from my transom.i cut/unplugged the wiring from the antenna and the GPS on the roof...On the bus i removed the corresponding connections and wires that these electonics were connected to........on the back of the rocker switch panel these wires are still connected( plugged into the back )..rocker switches are labeled interior lights, fishfinder etc......i presume that the bus i connected to the battery.
My question is...lets say i add a new fishfinder, can i use the same wiring from the old fishfinder that already exists and runs to the battery or do i have to remove all the old wiring that runs to the battery and start from scratch. If i can use the old wiring how to i connect the new fishfinder wiring to the bus and rocker switch....Thanks Tug
