- Joined
- Nov 3, 2003
- Messages
- 7,313
- Reaction score
- 2
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDO22289L405
- Vessel Name
- Captain's Choice II
I need a device that will count how many times my sump pump goes off in a given period and many hours/minutes it runs in that period.
Yesterday, the float switch on my sump pump float switch failed. (Naturally it was my birthday, what a present!) Luckily we were home and I was able to run a cord to it and plug it in periodically to keep the crawl space (4.5' high and concrete floor with a 2' sump) dry. Normally the whole space is dry, needed a humidifier in the house last winter to keep the hardwood floors from separating (first winter) but this year, with all the rain/tropical storms and high tides, the water table is somewhat above the floor and when the pump quits, the water starts to rise. We're about 300' from the creek and when the tide really gets high (about halfway to the house) the sump pump runs. It also runs during the summer because the condensate from the AC units goes into the sump.
Fortunately, the furnace and all other things in the spaces are a couple of feet off the floor but I'd like to have some kind of trend device that would tell me when the water table receeds. Have looked on the 'net but not found the right thing yet. I replaced the float switch today and it works fine again, I can hear it running about every 4-5 minutes. The only way I can figure out if the water table is going down is to time the events, which is sub-optimal to my engineer mind.
I have a whole house automatic start generator that starts when the power goes off so that is not an issue. If the float switch fails, it is a problem.
Any ideas/thoughts from the Brat community? I'd like to have a remote unit that installs on the living level of the house so I don't have to go down to read it, although there is access inside from the living level, which I use instead of going to the outside entrance.
Thanks...
Thanks...
