ddenver
- Joined
- Sep 24, 2007
- Messages
- 377
- Reaction score
- 0
- C Dory Year
- 2008
- C Dory Model
- 23 Venture
- Hull Identification Number
- CD0230011708
- Vessel Name
- C-Renity
I am afraid I am electrically challenged. At home, I can change an incandescent light bulb w/ no problem but fluorescents are a bit of a challenge. All I am really sure of when it comes to dealing w/ electricity is when you turn the switch on if the light does not come on there is a problem.
So, being faced w/ replacing the cabin water pump in our Venture 23' I am a bit dazed and confused. The Venture 23' has an automatic water pump which is giving me problems. When the sink tap is opened while the pump is switched on the pump initially works fine. However; after the water runs for more then a second or so the pump gets real loud (louder then the normal pump sound). Also, when the tap is closed, the pump keeps pumping for a few seconds.
I was told that this typically indicates an air leak. Tightening all the hose fittings has not resolved the problem. The fine folks at C-Dory sent me a new Jabsco PAR-Max 3 Automatic Water Pump with the idea that the pump diaphram might be bad. All I need to do now is put the new pump in!
In addition to the pump, they sent me some waterproof butt connectors. Per the West Marine catalog, these are "heat shrink connectors". Trolling around the internet I came across a few apparently related items. After reading these items I headed to my friendly neighborhood hardware store and purchased an AWG Stripper and Crimper tool. I then sought out heat guns - which I understood were needed to seal the butt connectors after crimping.
The only heat guns I came across were in the paint department and offered only 750F and 100F settings. This sounded like extreme overkill to me (too much heat!) so I asked the guy working in the hardware store. He told me I do not need a heat gun that the crimping tool was sufficient.
Is this correct? Do I need a heat gun to seal the butt connectors or not? If so, what power outage (750F?? 1000F??) do I need or should I be looking for lower temperature settings?
Any suggestion you can offer me in this regard are greatly appreciated. Do I need a heat gun or not? Any other hints and tips?
Nothing VENTUREd (C-Dory pun!) nothing gained.
Tanks,
Dan "Confused in Quilcene" Denver
Tanks,
