brooks&judy
- Joined
- Aug 18, 2015
- Messages
- 37
- Reaction score
- 1
- C Dory Year
- 2006
- C Dory Model
- 22 Cruiser
- Vessel Name
- Ticket
In Puget Sound and I presume in seawater elsewhere, there's a drive to replace creosote-impregnated wooden pilings to improve water quality. The most common replacement in my town are pilings of galvanized pipe. They've greatly increased electrolysis problems in our already 'hot' harbors.
The rudder zincs I put on my SS trim-tabs and the bar zincs under the outboard brackets fizz away like Alka-Seltzer on my 22 Cruiser. I asked a marine engineer about those steel pilings. He said they create incredible hot-spots in salt water in a roughly 4' radius around each pile. The effect reportedly tapers off further away, but is still harmful to more noble metals 12' or more distant.
I spun my C-Dory in its berth to get its rump around 20 feet from the nearest piling and the fizzing slowed but not enough: Trim-tab zincs top & bottom (3" dia.) last around three months, the bar-zincs on the motor brackets around six.
I decided to trailer-boat. When I pulled it out and scraped a bit of the transom drain tube with my pocket knife, it looked like copper - not good if it began life as brass.
Anybody know if those tubes in `06 C-Dorys were indeed brass or did they start life as copper?
I can't find any perforations in the tube - it's not turned to lace yet. For now I've coated the tube liberally with a lanolin-wax and intend to seal off the drain tube with an oval piece of Gorilla Tape over its outboard side in hopes of isolating it from seawater if I use the boat before replacing the tube with a composite.
I'm not used to having a transom drain and have never needed to use this one. I think I could push the Gorilla Tape off with a broom handle from inside the cockpit. I doubt I'll need to, having two electric pumps, a bucket, and likely soon a 10" diaphram pump.
Any words of wisdom from the more experienced?
Thanks!
~ Brooks
Thanks!
~ Brooks
