tparrent
- Joined
- Dec 23, 2009
- Messages
- 285
- Reaction score
- 0
- C Dory Year
- 2017
- C Dory Model
- 255 Tomcat
- Vessel Name
- Tomfoolery
I was out exploring the industrial rivers of New Jersey yesterday (hey, you boat where you can when you can) and had a wee problem with my engine.
The Honda 90 has been flawless to date and only has 60 hours on it (2007 C22)
With the engine running, I switched from the starboard to the port tank. The engine ran fine for five minutes then quit. Of course it quit under a bridge as another much larger vessel was coming through. No sense in it quitting in the quiet marsh with nice soft shores to drift into!
I switched back to the starboard tank and was able to restart the engine. As I had let the starboard tank run low, this led to a little excitement with a container ship and three tugs in a tidal race but that's a different story...
When I got back to the dock, I switched to the port tank again and ran it for five minutes with no problem.
This morning, I headed out again using the port tank. After about ten minutes, it quit. Of course it chose a tight spot at the marina exit with a big tour boat coming up behind me.
I switched back to starboard and the engine ran fine.
The fuel in both tanks has almost always come from the same pumps so I would be surprised if the fuel itself was bad.
Do you shut down the engine before switching tanks? Do you have to prime the fuel line when switching?
Where do you think the fuel came from that kept the engine going for five or ten minutes?
Tom
Tom
