joechiro30
- Joined
- Sep 24, 2014
- Messages
- 145
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 255 Tomcat
on our twin 150df Suzuki's the starboard side is not starting. The tilt button from the throttle controls is not allowing the engine to tilt from the handle either, but the port side engine starts fine and tilts fine.
We are checking to see if there are wire problems. While looking into the wiring from the throttle we are wondering if the throttle sensors work along with the safety neutral switch. Both are in the same place and use the same linkages. One switch is the safety neutral switch and the other is called the throttle position sensor switch.
thanks for your input.
