tpbrady
- Joined
- Feb 7, 2005
- Messages
- 891
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Bidarka II
If I understand the way the cooling system works when the motor is first started and when cold, either the thermostat or pressure relief valve will let some water into the block. The thermostat almost has to be on the outlet so I would assume it would be what ultimately controls the low temperature operation. As the engine warms up the thermostat would open to allow more water through. The pressure relief serves two functions. If temperature rises rapidly and the thermostat doesn't open resulting in a buildup of pressure, the pressure relief valve would let more water through the block. In addition at high speed through the water the increasing pressure could also open the pressure relief valve allowing more water into the block. The pressure relief is like a radiator cap releasing under too much pressure, except in this case it is more fail safe in its operation as it introduces more cooling water into the motor where as the radiator cap just let's you know things got too hot.
Makes sense that one or the other is not doing its job. At $7.50 per plug and $30 per gallon for oil, the fix is priceless so to speak.
Rabidfish, your tips on indexing were right on. I went three for three on Saturday. I just had to swap one from the 2 slot the 3 slot and they all got within 90 degrees.
