B~C
Active member
- Joined
- Oct 31, 2003
- Messages
- 2,888
- Reaction score
- 10
- C Dory Year
- 1999
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- 860
- Vessel Name
- Blue~C
Concerning Wise sales- I'm leary of mail order, always like to kick the tires and fondle the merchandise before laying out the money but Wise had by far the best prices on the Honda EU2k so I took a shot. One call and four days later there was a nice little gen set at my door as advertised...good outfit, two thumbs up.
I debated 1k vs 2k gen sets and decided that the 2k was only about 14# heavier than the 1k (what the heck is 14#? most folks pack more than 14# of beer onboard). Another consideration is that with, say, an 8oo watt load that 1k machine is going to be running hard wheras the 2k is going to be just loafing, less rpm, less noise....mind you, ideally for the health and efficiency of the generator, loafing isn't a good thing so when I fire up the hot plate and the heater it gets loaded...that little $14 electric hot plate is sure a handy item, you'll be surprised at how many otherr handy electric items you'll run into once you have juice onboard (that's where the weight comes in)
Sea Wolf Joe and I where fiddling around with generator gas caps the would allow you to hook up to the main fuel tank for extended running. I purchased a Honda fitting and installed it into a gas cap from a Harmony mower, this allows one to unhook the fuel line from the outboard and hook it to the generator....aint field tested it yet, should work.
don't forget to get a CO detector
