Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,897
- Reaction score
- 241
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
There are two models of the davit, and the basic difference is the tubing diameter--The smaller tubing is rated at 100 lbs, and the larger is rated at 150 lbs. The rest of the davit seems to be pretty much the same.
In an emergency, I would pick up a person. I would not consider unless it was an emergency. For the 150 lb davit, I think it would be reasonable for a 200 lb person, and the 100 lb davit, a 150 lb person.
I am sure that there is a considerable safety factor built in these davits, and that the weakest links are the tubing itself, the upper attachment and the support for the arm. You can hoist using one of two methods--one is thru the davit arm, to a jam cleat on the body of the tubing, and the other is thru a cam cleat on the upper arm. I would use the latter for hoisting a person, since it puts less down force on the arm out beyond its pivot point.
