Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,939
- Reaction score
- 284
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
The problem using the flushing port, is that the water pump housing and lowest part of the housing/intake is not flushed with fresh water. You can probably get away with flushing using the port, as long as you peroidically run some "salt away" thru the lower unit, and replace the impeller regularly.
On the CD 25, the previous owner had not raised the lower units out of the water for the entire 3 seasons he had used the motor--and I suspect that he didn't flush the engines. Only 120 hours on the engine. There was some corrosion on the external part of the lower unit, but none on the internal part. There was some minor salt crystal build up in the pump discharge, but again not bad. I flushed the engine with "Salt away" (it kills the grass!, so the Admiral was not too happy!) The impeller and housing looked to be fine.
