Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 10
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
colbysmith":2gl5o24q said:Just replacing the cutout with board lips sounds like a good inexpensive idea, if I cut on top the area
I imagine it varies from person to person, but I actually prefer the "loose hatch" style and not because it's cheaper (I find it's actually more work because the cutout will show, and I fabricate a lid, plus futz with the cleats/installation), but because I find it easier to access when possibly burrowing under a cushion. Yes, sometimes I remove the whole cushion and put it somewhere else, but inevitably there are times I just want to reach in and grab something without moving the whole shooting match. With a flat lid you can just slide it to the side and then reach in the hole, perhaps propping the cushion up. Seems like a hinged lid would make that less pleasant. On the other hand, by using a pre-made hatch unit with hinged lid, you can just cut a hole, no need for it to be perfect, and drop the hatch in..... so I can see that preference too.
I am very interested in the hatch rim that Mike recently showed on his Glenda Jean, because in a way it's the best of both worlds. I couldn't find a like one online, but then it's a difficult item to find precise search words for. It almost looks like either a window frame unit but without the glass, or a long extrusion that is bent around some kind of form on site?
I suppose one could use the cutout as the hatch lid, but I imagine it will have a somewhat "unwonderful" edge due to being cored. It could be smoothed though. I figured I would probably make lids of nice plywood, but I guess I'd have to see the cutouts first. I wouldn't use mechanical fasteners for the cleats, but would epoxy them beneath and clamp them to the top as they cured.
