Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,946
- Reaction score
- 291
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
This is a U Tube video by Pete Melvin of the the yacht design team of Morelli and Melvin on the Aquila 36 Catamaran.
I have long criticized the Tom Cat 255 as having the bridge or wing deck too close to the water and the tunnel closed when at rest or lower speeds. This affects both performance and ride in the boat--and somewhat limits its capability as the seas build. The hulls should be about 6" deeper (or the bridge deck 6" higher). I attribute some of this to the same basic hulls being used in the Tom Cat 24 (which was the mold that the 255 hulls were taken from) and increased weight on the 255. The Tom Cat 30 (Black Feather Marine 30 or Chil Kat30) had an open tunnel and is a better performer--probably would be ideal for conversion to a foiling cat.
Morelli and Melvin have been one of the premier design teams on both catamarans and more recently on the foils for many boats, including the most recent American's cup sailing boats.
In this video they discuss the foil advantage (35% fuel savings) in the 36' Aquila catamaran. If this concept could be taken to the Tom Cat, it would be a huge plus. in ride and efficiency. Unfortunately it would not help the issues at rest or low speed. Also trailering could present a challenge with the foil.
Now all we need is someone with a lot of extra dollars and a Tom Cat they wanted to chop up--or buy a hull from the factory, and make it higher, and add a foil, then drop the standard cabin and interior on the boat. Probably would require extra long shaft outboards also-
