marco422
- Joined
- Sep 25, 2008
- Messages
- 103
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 16 Cruiser
- Vessel Name
- Gaiasika
Thought I would ask about the most common mistakes boaters make. I would start with the obvious ones:
1. Leaving the transom plug out. I've done it twice. The second time I went to park the car and came back to six inches of water. I couldn't understand why the bilge pump wasn't bailing the boat (bailer was running) until I realized I had installed the check valve backwards when I previously rerouted the pump outflow. Had to do a repair while kneeling in a foot of water (the boat tilted with my weight in the stern).
2a. Not engaging the kill switch. Sometimes happens to me in spring when everything has been put away through the winter and routines are forgotten. One year I brought the boat out and confidently tried to start it. No matter what I did, it wouldn't fire and I began to take apart the fuel system and the sparks. Finally I opened the manual and realized I had forgotten this essential.
2b. Trying to start the engine in gear. Occasionally happens when the engine dies in a tricky spot and you get that momentary panic when it won't restart. Calm down and think it through...
3. Forgetting the keys. I went on a two hundred mile trailer trip and realized I had forgotten the boat keys. Thankfully a thorough search of the boat turned up the spares.
4. Not opening the gas tank vent. Done this a couple of times. Realize my mistake when the engine dies and the gas tank is sucked up into a concave shape. I guess that reverses the gas tank set from swelling during the hot days...
5. Leaving the motor down on a gravel road. Only done it once. Didn't like all the resulting stone chips.
Don't know if I am particularly absent-minded or these happen to everyone.
