Hi Phil, Your table/seat project looks good. I have questions about your kicker mounts pictured on your site. Why did you go to the trouble to move the swim platform to the other side? I'm interested in mounting a kicker, mostly for trolling I suppose (although as a long-time sailor of trailerable boats, the idea of backup propulsion is always there.) Did I see a post where someone (Cbrat?) got a tie-bar from Cabelas that linked the steerage of both motors together? Throttle and gears might be a problem on a simple set-up for anything less than open water steerage. Has anyone thought about putting a "vertical board" on the back of the swim step to serve as a kicker mount? It is far back in terms of reach, etc., but an extended tiller-arm might take care of some of those problems.
Rod McNabb
