Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,821
- Reaction score
- 181
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
The Nida-core is in place. All exposed balsa from the old deck has been sealed with epoxy and the area between the Nida-core and balsa is filled with epoxy. The Nida-core is laid in place with a layer of 1 1/2 oz mat, over the previous inner laminate (1 1/2 oz mat and toward the bilge is 18 oz roving one layer). Next, another layer of 1 1/2 oz mat will be laid where necessary to make the new core exactly flush with the existing deck. All of the gelcoat in the areas where we step has been ground off, and the biaxial cloth will be laid on top of that. Finally this will be faired and either regel coated or alwgripped. (which ever is easiest). It is interesting to note that there were several "impact" areas over the intact dry balsa core, where the single layer of 1 1/2 oz mat had been damaged when some object was dropped on it (Maybe a heavy fishing sinker?). With the new Biaxial cloth, the new cockpit floor will be stronger than the orgional by a factor of at leat 10 fold and resistand to any impact damage.
The last photos in the "Thataway" Album show the Nida-core in place, and the cut out for the bilge pump access, to show the structure of the Nida-core.
