alainP
- Joined
- Oct 7, 2016
- Messages
- 238
- Reaction score
- 8
- Location
- Tucson, Az
- C Dory Year
- 2011
- C Dory Model
- 25 Cruiser
- Vessel Name
- deja la
I have a 2011 25 cruiser with the water tank under the center of the splash well, it seems to have developed a leak, not a big one, maybe a pint a day or so. At first I suspected the lower hose connection (pump feed) but that's clearly not the source. The two others fittings (fill and vent) are way up on the tank and are dry as well. There must be a small crack somewhere, access to it is difficult and as far as I can determine removal of tank cannot be done without cutting out a lot of the splash well (out of the question of course),
There is about 7 to 8 inches of space between the top of the tank and the underside of the slanted splash well, I am thinking that the only solution to this might be to cut out the top of the tank which looks to be HDPE and drop in, somehow, a bladder tank in the resulting "box". Has any one dealt with this problem and is there another simpler solution evading me? Is there a recommended brand of bladder tanks? Thanks
