- Joined
- Nov 2, 2003
- Messages
- 8,561
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Daydream
Live and learn - that is what we all hope for anyway! A year older, maybe a bit wiser. Last year, we blasted Daydream around at WOT whenever the water conditions would allow. We also ran with the engines in full down position all the time, because we didn't want the bow any higher than it already was. This year we learned a couple of things.
First, slow(er) cruising. WOT for us is just a little north of 5500 rpms (standard factory issue three blade aluminum props). This year a conscious effort to run at 4400 - 4600 rpms most of the time. Instead of 23 - 25 mph, we are now running anywhere from 14 - 20, set the rpms and let the speed float with wind, current, load, etc. This is where the Honda 40s are most efficient, I just take that on faith from the published info.
Second, trim engines up. We get the same rpms at lower throttle, or higher rpms (and speed) at same throttle setting, compared to full down position. Patty just has to sit on two cushions to see over the wheel now! Bow up is the natural position for a C-Dory they say!
The result - a significant increase in fuel economy, old way was always south of 4 mpg. A lot of the time we were in the 3.5 - 3.7 mpg range. New way - we are creeping up on 5, have not got there yet, Blakely trip (cruise over, whale watch cruise, cruise back = 97 miles on 22.9 gallons, or 4.6 mpg). I think with a light load, calm water and favorable winds and currents, we could turn in a bona fide 5 mpg...The other benefit is invisible, we are HOPING that this program will extend engine life as well, again taking this on faith.
