Well-known member
- Joined
- Oct 27, 2012
- Messages
- 3,678
- Reaction score
- 26
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- SoBELLE
I find that unless I pay very close attention when fueling (and even then) I can easily end up fountaining fuel out of the filler when the tank approaches full. I have checked the fuel vents and they are working, I can feel the air coming out when the tank is filling.
I also recently replaced my fuel fill hoses so there are no problems with them being plugged up and I made the run a bit straighter to the tank with the new fillers.
I have seen fuel fill check valves. Both Attwood and Perko make them. The Attwood ones are inline in the fuel filler. The Perko ones are also inline, but they fit inside the fill hose or at the tank inlet, so there is not an addition joint like with the Attwood ones.
http://www.perko.com/catalog/fuel_syste ... t_fitting/
http://www.discountmarinesupplies.com/I ... gIspvD_BwE
http://www.attwoodmarine.com/store/prod ... trol-valve
I have one of these. It helps, but only if it is firmly pressed down to the filler neck (the chain for the filler cap doesn't let it seat very well).
http://www.boatstoreusa.com/fuel-tanks- ... gIo-_D_BwE
Has anyone tried any sort of filler check valve? Did it help?
The only thing that prevents the fountaining is filling the tank very slowly once it gets about 1/2 full.
Thanks.
Thanks.
