Ken O
My new-to-me boat came with a big Racor-type (I think it's a copy-cat) primary filter/water separator. It looks like a Racor 320R-Rac-01, which is rated at 60 GPH. My Honda 90 shouldn't drink more than 10 GPH wide open. Anyway, I need to replace the plastic bowl, which fell off in the hot sun the other day and leaks badly (threads slip before they get tight). The bowl has been hard to find, and a whole new assembly is around $100, plus I need to change to 1/4" NPT fittings.
I'm wondering what other people running motors around 90 HP are using? Is there an advantage to such a big filter? Defender sells a Honda OEM primary filter and water separator rated at 25 GPH for $75. Either way they are all 10 micron. As long as parts are available, maybe I should go with the Honda. What are people using and with what results?
Thanks!
Thanks!
