Tug
Active member
- Joined
- Jun 22, 2007
- Messages
- 1,006
- Reaction score
- 9
- C Dory Year
- 1985
- C Dory Model
- 22 Angler
- Hull Identification Number
- DOR22241H585
- Vessel Name
- Drifter
I am finally getting around to replacing my fuel lines.The fuel line size from the gas/water separator to the motor is 5/16 inch ID. The fuel line from the gas/water separator to the gas tank is not marked.( the size of the hose). Can i assume that the gas line entering the gas/water separator is the same size existing the gas/water separator.Also should the squeeze bulb and fittings be a size lager than the hose to get a tight leak proof fit.Tug
