Roy & Dixie":w0d09hop said:
My original vent lines also not only had the vents mounted lower than yours, as you noted, but the lines routed straight down to the tank vent connection with no upper loop.
Ah... I see. When I first saw that some boats had lower vents, I was a bit envious thinking they had nice high loops (whereas mine didn't have room for them).
I have no way to now create a loop since the vent it installed as high as possible exiting into the splash well.
If you have an inch (or maybe it's 1.5", I forget now) to spare (from center of hole to underside of deck), then, if it did prove to be an issue on down the line you could install the P-trap vents. My original vents were so close to the underside of the deck that I didn't even have that much room, but I found that they make a flush version, and by making the larger (required) hole "off center" of the original one (but including the original one in it) I was able to fit the P-trap vents to the original holes.
When I stated incorrectly that the vent is now higher than the fill port, I should have said that the vent is now higher than the point the fill nozzle reaches in the tank fill hose.
I see what you mean. I also discovered that it helps to put the fuel nozzle in such that the curve is bending aft (sort of backwards to how you would normally think to do it) and mimicking the bend of the fill hose. I can pump slightly faster that way. (I did get some fuel out the vent the first time I filled, when I was merrily pumping away like it was a car; not sure, but I think maybe it had to do with the turbulence generated where the incoming fuel hits the top of the fuel in the tank. Now I go slower and watch that turbulence and have not had it happen again, but I do fill fairly slowly and now face the nozzle aft.)
And the mate can stand by the vent inside the boat to easily catch any vented fuel, whether at the dock or at a service station while on the trailer.... In addition, any spilled fuel will be into the splash well. It would take several ounces before any fuel would exit overboard to sea.
That does sound good as compared to having it run straight overboard.
I'll post how this all works out after my next outing. I'm planning a south bound ICW trip from Daytona to the Keys, possibly to include the Kissimmee River from Lake Okeechobee. I hate to think what that fuel bill will be.
Sounds fun though! Will be interested to hear how you like the vent improvement (and of course any trip updates).
