Ctarmigan
- Joined
- Nov 14, 2019
- Messages
- 54
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CD022102J304
- Vessel Name
- Ptarmigan
Hello all,
Having recently solved (hopefully?) a water-in-fuel-tank problem, I thought I’d document here in case it’d help others.
Quick background: during spring prep this weekend, I replaced my Racor filter. On filling the dry filter from my starboard tank, I collected lots of water (50:50) in the filter bowl. Bad news.
Water Removal Steps:
I believe now I’ve removed (nearly) all of the water from the bottom of my starboard tank, and identified no water in my port tank. I smell like a refinery, but at least the issue’s dealt with.
Couple questions for the pros here:
Sorry - no photos of my progress; didn't want to be fiddling with my cell phone while surrounded by gasoline fumes, either.
Oliver
- 1) Access the fuel tank – I unscrewed the fuel pickup tube on the starboard tank, and pulled it out of the tank. Stuck a little at the bottom of the tube, but with some of patient wiggling I got it out of the access fitting.
2) Tilt the tank – I dropped the tongue as low as I could with the jack, and then raised the rear starboard corner of the trailer, and supported securely with a jack stand. Now the lowest part of the starboard fuel tank was roughly below the fuel pickup tube access I’d opened up.
3) Suck out the water – I’ve read a lot online about using a 12V fuel pump to suck fuel out of a tank. I’m a chicken – I don’t like mixing gasoline and electricity outside of an engine block – so I opted for a non-electric option. I used a manual fluid transfer pump (https://www.canadiantire.ca/en/pdp/motomaster-fluid-transfer-pump-0283047p.html) to pull water/fuel from the bottom corner of the tilted tank, and transferred into a clean 5 gallon bucket. A little slow – it would take quite a while to empty a full tank – but by the time I’d extracted ~5 litres it seemed I’d removed all the water, and was just sucking up plain gasoline.
4) Try the port tank – I tried the same approach with the port tank, but found I couldn’t remove the fuel pickup tube because of some dinged up threads. Not interested in reefing too hard on it, and risk tearing it out of the plastic tank entirely, I looked for a different option. Chose to remove the fill vent hose instead – it came off easily, and the tilt I’d already put on the whole boat meant the low end of the tank was pretty close to that access point anyhow. Extracted ~5 litres of fuel using my same fluid transfer pump, with no water visible. Water seemed like just a starboard tank issue, but I was glad I checked.
5) Clear the lines – I assumed there was still some water tucked away in the lines from my starboard tank to the Racor filter. To clear this, I alternated filling and draining the Racor bowl until it stopped receiving water in the fuel. To refill the drained Racor bowl each time, I opened the ball valve at the motor end of the fuel line with a finishing nail, and pumped the bulb, draining the fuel into a small container. The Racor bowl filled quickly as I did this. I expect there’s an easier way to do it than I did (e.g. opening the vent on the Racor filter fitting – but I couldn’t find my Allen key set). I also tried the port lines, but found no water there.
- 1) Having delivered a slug of water to my new Racor filter, should I replace it?
2) Should I add some gasline antifreeze (e.g. Heet) to deal with any small amount of remaining water in my starboard tank (or just rely on my Racor to keep it out of my outboard)?
Oliver
