- Joined
- Nov 2, 2003
- Messages
- 8,561
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Daydream
So on Wednesday's return from the Pender Harbour CBGT, the fuel water separator alarm went off just outside Point Roberts. We came in with the alarm sounding, and after clearing customs proceeded on to Blaine with the alarm sounding. I think what happens is whenever we are in really rough water, whatever little bit of water might be at the bottom of the tank from condensation or whatever gets stirred up and, as it is supposed to be, captured in the fuel-water separator under the cowling (this is not the external fuel water separator, that had no trace of water in it).
This has happened twice before. The first time in 2009, a friend on a sailboat came on board and took care of it for me. I wrote this up on my blog in "Life without Touch". I think this is one of my better pieces of writing. Mostly, I thought I understood what he did and how to do it myself if I needed to.
The BF150 manual I have shows the fuel - water separator in the wrong location (it says it is next to the oil dip stick, when in fact it is on the opposite side). It is tucked under the manifold, and appears too large to get out from under the manifold and over the edge of the lower unit. Somehow my friend wriggled it this way and that way and this way until he coaxed it out. There are actually two bowls inline with each other, and you probably need to remove the gas and water from each one. The actual fuel - water separator is the one with the wiring harness attached.
The next time it happened was probably the following year. I went to a protected area and proceeded to deal with it - over water, no less. I apparently also coaxed it out and got it back in somehow. I thought OK, this is a real bitch, but I can deal with it.
So yesterday, in my own driveway, not over water, with a piece of carpet below to catch anything I dropped, I tried again. Got the second bowl out (the one without the wiring harness), somehow, and there was quite a bit of water in the gas - easy to see when it separated in the little jar I put it in. But I could not get it back in to save my soul, and I decided after literally hours of fruitless attempts, to cry "Uncle." I called Blaine Marine, he said tow it in and he would fix it Monday or Tuesday. The repair order says "Owner messed up fuel - water separator, make it right."
I guess my questions at the end of this epistle are whether anybody else routinely deals with the fuel - water separator, and if so, HOW? How do you get it out and back in that incredibly tight little space? And a rhetorical question, why the heck did Honda put a routine maintenance item in such an inaccessible spot? I get really down on myself when stuff like this happens, and question whether I should even be boating at all, given my inability to cope with stuff that every six year old in Alaska can do. But I suppose as long as I have enough money to have somebody else fix it, I will keep on boating!
