The reason why I said it was a Blue Seas panel, is when you go to West Marine's website and find that product, then click on the link for Specifications and Wiring, it takes you to a Blue Seas pdf document.
Strange, because on my computer the pdf document says West Marine in multiple places.... I didn't sea "Blue Seas" anywhere. But I may have missed it?
Yes, many items are made in China--but there are quality items, vs cheap items. I tend to equate Blue Seas with quality. Blue Seas is a Power Product company, and their other lines are also high quality products, like Mastervolt, ProMariner and Ancor.
Looking at the original photos, there is the face of the added plastic panel which has the west marine breaker panel. On the second photo is a picture of a Fuse block with 12 fuse positions, which appears to be a Blue Seas product, but without its proper cover. That has mostly less than 16 gauge wire coming off--and what I would best guess is 10 gauge at the max feeding it. Most of these Fuses seem to be 3 to 5 amps
Is this the point where bmcminn wants to take power from for the cigarette lighter plug and UWB or is it the West Marine breaker panel, which appears to have two unlabeled (unused?) breaker slots (the lowest)? So where does bmcminn wish to take the power from. This would have bearing on the size of the wire. We would also want to know the distance the wire would run--as per my original post. But I would not put any more than 10 amps on this particular cigarette lighter type of plug. I don't see any indication that this is a Blue Seas plug or USB port--there are many of these ports available on Amazon etc--and many are not rated for more than 10 amps.
Brent--why do you feel that the cig lighter plug and USB port should be moved?
The standard C Dory panel (which appears to have been removed) in most boats has a plug in this location. In my boat, I have a USB 2 plug (with a 2 hour timer--and this may be important--because of over charging batteries) to the right of my helm. It is very handy to recharge or keep charged I pad for navigation (which many C Brat use). In our case we have 2 other stations, but in a 19, this seems like the logical place for the USB charger port.
