Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,774
- Reaction score
- 123
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
We put our Garhauer Davit on the CD 25 for several reasons--to hoist the 15 hp Honda Kicker onto the boat from its stand, or move it from the C Dory to the 10 1/2 foot inflatable. We also can pick up objects from the dock and swing them into the cockpit, or items from the cockpit to the splash well (like the Honda generator). Would it bring a person aboard? It would at least help get them out of the water, and into the splash well--which is better than leaving them in the water....
We put the kicker on the stb side, because it was already cluttered with the cables and hoses. There are 3 70 lb batteries on the port side to balance that weight.
I also put up a photo of the two AGM's we put on end in back of the water heater. These will give a back up house source for the refigerator and run a 1500 watt inverter to run the microwave when not pluged in to some 110 V power support. We have a split plug for the microwave--one socket for the mains power and one plug for the inverter--this does away with a switching inverter or the necessity for a transfer switch. The inverter will be turned off with a switch mounted aft of the water heater. (more photos of that in the next day or so).
