Garmin GFS10 fuel sensor install
Active member
Sep 30, 2006
4,698
23
2007
25 Cruiser
'Au Kai (Ocean Traveler)
Installing it myself. Instructions state is must be affixed to the boat via a mounting bracket and zip ties that mount the fuel line on either side. Where it's installed, there is no way to do that without gluing a mounting board (Starboard). I know gluing Starboard can be problematic. Do I have to actually mount the unit or can I just leave it as is, in the middle of the fuel line run?
It is in the starboard battery compartment, way in the stern corner above & behind the starter battery. It's not going anywhere. Am I missing something? Or is Garmin just being liability averse?
I think the reason they want it mounted is that they want the sensor oriented so the fuel flows vertically / upward through it. The manual states that this is to avoid air bubbles. I have twin 90s, so have two GFS 10s.
I just used 5200 to adhere a scrap of wood (cedar) on each side and mounted the GFS 10 to that. I used a dab of hot glue to keep the board from sliding down while the real adhesive set. Pretty quick and easy.
Here's a pic of one side:
Thanks beerman. I guess I'll just glue a piece of teak under there. I didn't even mount the Garmin-supplied filter, as the fuel system already has a screw in (oil filter type) mounted prior to the sensor. The sensor is "vertical" where I mounted it. I'll just do what they instruct.
I have put the sensors in position where the fuel line was assured to be vertical, because of its attachments. They worked fine. It is most likely a far better idea to use a mounting board.
