jkidd
Active member
Looks like Garmin has stepped it up again. This is impressive.
https://m.youtube.com/watch?v=GnUoQcBOwtQ
jkidd":b1m9eb9p said:Looks like Garmin has stepped it up again. This is impressive.
thataway":c26ru4wb said:Yes, that looks good for fishing, up to 25 feet away in shoal water....but what about real life cruising to avoid obstructions?
gulfcoast john":2fe3oaxb said:Jay,
Thanks for your post.
Without it, I could not have imagined why anyone could need or want this technology, which is by all accounts in its primitive stage.
We all respect your vast experience, thanks again!
hardee":dkldsrye said:That just looks so great. I talked to the guys at Rodger's Marine about doing something like that. They discouraged me from doing it with the Raymarine RV-100 Chirp and down vision 3D.
hardee":tq6wky3y said:Well, #1, It would have taken custom fabrication, which they could do, but it would have taken more time and they had me on a 3 day time slot.
#2. The picture on the screen would not rotate 90 degrees, it would, they said, just present a narrow line, not the wide side scan that I was looking for.
#3. They were concerned that the side presentation of the RV-100 transducer would put too much stress on the the transom attachment and on the transducer itself. Even after assuring them that it would only be deployed transversely at 0-2 or 3 knots. (It is quite long and not so narrow, but the mount is not nearly as robust as the P-66 that was there originally.)
I did send them the link to this thread so they could see the pix, but that came about after I had already set up my schedule and I was already there. Didn't really want to turn around and bring the boat home then back again for it to be later.
For now, the 3D view and the side scan views will work pretty well, but for some spots, I will turn the boat 90 or back into an area if I have to. Many places I anchor I can see the bottom (5-10 foot depths) so the sonar won't be that much of an advantage. Where I can't see, it will be a big plus.
