Socrateur
- Joined
- Feb 16, 2006
- Messages
- 244
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Sea Skipper
I know that a drive train such as the duramax/allison combo is ideal for heavy duty towing for those who tow frequently. But from a cost vs. benefit perspective, does this rig make sense for someone who will only tow occasionally, such as four to six times per year covering, say, 3000 miles total? I'm looking at a 3/4 ton truck and it will not be a daily driver; it will be a dedicated tow vehicle which will sit idle for months at a time between uses. The boat will be towed up and down 7% grades and over 5000 foot mountain passes. Typical route will be Hwy 5 between SF bay area and San Juan Islands, 840 miles each way.
I'm wondering if a V10 gas engine makes better sense for my needs. My concerns about going diesel are numerous: the diesel rig costs $8k -$10k more and diesel fuel costs more than regular gas. The new diesel motors are a lot more complicated than they used to be with all of the emissions stuff, low and high speed turbos and the like. As a result, lower gas mileage than before. I've read that diesels don't like to sit for long periods of time, and maintenance is more expensive.
The only con for V10 I have is even worse gas mileage than diesel. Anything else? Again, I realize that diesel is king, but keep in mind my limited use parameters. Still go with diesel or go with a V10? Thanks.
