Well-known member
- Joined
- Oct 27, 2012
- Messages
- 3,729
- Reaction score
- 68
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- SoBELLE
Schuster":2fw40q96 said:Thanks John and Bob. I believe if I tap into the the fuel line near the racor filter that I may be able to keep the rise near 12". If I find a 90 degree hose barb to cap adapter it would help to minimize the rise also. I'm considering a quick disconnect rather than a valve to reduce fittings and hardware.
SSBOL I haven't looked at the racor filter yet for outlet ports yet but i may have to experiment a bit to see if I will have troubles drawing enough fuel. It could be that the 2000i draws a little better vacuum than the 1000 model.
The rise on a C-Dory is measured from the bottom of the tank (worst case scenario) to the fuel inlet on the generator, which if you use a ported cap is basically the top of the generator. You may get some help if you fill up the generator tank and the fuel feed line with fuel so that there are no air voids.
