Doryman
- Joined
- Oct 3, 2006
- Messages
- 3,807
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 255 Tomcat
- Vessel Name
- Lori Ann
Those of you who are familiar with my Tom Cat know that a couple of seasons ago I took out the factory windlass and replaced it with an EZ Anchor Puller. I originally filled the drum with 1/2" Brait and 50' of chain, but found that I could only put a portion of the calculated capacity on the drum. Replaced the backing part of the Brait with twice as much 1/4" high-tech Kevlar-like Plasma from Puget Sound Rope here in Anacortes. After a lot of fiddling I ended up with 30' of chain, 75' of Brait and 125' of Plasma. But in order to get even that much to fit on the drum, I have to lay the rode on the drum as it winds in, otherwise it bunches up in the middle and jams against the windlass housing and/or the deck. Having to manually lay the rode is not only inconvenient it can be dangerous if you get your fingers caught.
Tonight the Admiral gave the order that the EZ Anchor Puller must go and that we should revert to the original factory windlass. If I am not mistaken, that windlass is the Lewmar Pro Series 700H -- would some other Tom Cat owner please verify that? Unfortunately, I sold my original windlass to Roger on the Sensei so I need to buy a new windlass. I did not hear anything bad about the Lewmar or have any problems with it, but I welcome suggestions as to alternative windlasses to consider. And if you have a 700H for sale, let me know.
Finally, anyone looking for a good deal on an EZ Anchor Puller? I still like this windlass and think it would be awesome on the right boat.
