robhwa
Active member
- Joined
- Dec 4, 2013
- Messages
- 369
- Reaction score
- 39
- C Dory Year
- 2003
- C Dory Model
- 22 Cruiser
- Vessel Name
- Marcia C
thataway":14829c6p said:Which DC to DC charger are you using? I have experience with several (Victron and Sterling). Neither of these will "Priortize" the start battery, any more than a VSR does. (I am using a VSR between start and house--and the DC to DE to a 3rd battery bank--both in the RV and was in Thataway.
Renogy DCS50S...from the manual and online:
- Designed to charge service batteries from two DC inputs—solar panels and alternator
- 3-phase charging profile (Bulk, Boost, and Float) ensures your service battery will be accurately charged at the correct voltage levels to 100%
- Trickle charges the starting battery via solar panels if the service battery is fully charged
- Isolation of the starting battery and the service battery
- Temperature and voltage compensation features prolong battery life and improve system performance
- Features: battery isolation, over-voltage protection, battery temperature protection, over-current protection, overheat protection, reverse current protection, solar panel and alternator reverse polarity protection
- Compatible with multiple battery types: Sealed, AGM, GEL, Flooded, and Lithium
Nice combination solar + alternator in one package. If it had a 1000 watt inverter it would be perfect.
These are reasons I picked this (installed under sink in dry environment in the boat) for both my camper and boat. I eventually replaced all AGM house batteries with LiFePO4, Renogy (cheaper, lighter), in camper and BattleBorne in boat. So far, so good.
