C-Wolfe
- Joined
- Sep 16, 2020
- Messages
- 365
- Reaction score
- 5
- Location
- Anchorage
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Valhalla
I have a Guest 3 bank charger 5-5-10 that I assume is original equipment for my boat (2008) and does not support LiFepo4 battery charging. I upgraded my house bank to 2 Lifepo4 and start to AGM, I also have a DC-DC charger from each start battery charging the house bank. I do not feel the need to replace the built in charger anytime soon since I do not typically spent much time in harbor. I keep the boat park at my house and anchor for the night while I’m out on the water so no real advantage to have a nicer built in set up. So here is my question, can I use the 10 Amps on one of the start battery and connect both of the 5 amps on the other battery? Having 5 amps on each will be adequate to top off the start batteries but at 10 amps each, I could let the house bank getting charge from the DC-DC charger. I do have a portable charger for Lifepo4 that is easy enough to use for the house bank but plugging-in the boat through the shore power and flipping a switch is even easier.
