Hand Holds
toyman
Jan 11, 2009
556
1
2006
Fan-C-Dory
I'm trying to locate the hand holds that some have installed on the brow of their C-Dory's - any pointers are appreciated. I can't even locate photos of the installs now.
Here's a previous thread that discusses this (it includes a few photos). The hand holds on Thataway Bob's boat are similar to those on the outside aft end of the cabin and are readily available at any marine store.
These work great, but they're patented:
Al
Moose - those cost WAY more than I can afford !! I have an old set of Reindeer horns (antlers ?) that I got in Finland, will they do ?
These things are easy to find once you figure out that they are "grab rails" not "hand holds" :oops: . Course my Grandma always said not to grab, now what ? Just wear swimming suit when on deck I guess.
I can see little kids crying... "Look, Momma - that boater guy killed Rudolph!" :cry
Yeah! Would be even worse if he put a big red nose on the bow pulpit! :xlol
I don't know if the Finlander kids knew anything about Rudolf, or not, but there was sure some finger pointing driving the old VW bus back to Norway with the horns (antlers) strapped to the front end.
I knew the VW Bugs would float for a period of time, but didn't know that to be true of the VW bus. Perhaps having the proper set of antlers strapped to the front end enabled the VW bus to make the trip across the BIG lake.... :lol:
Well, at various times the old bus floated from Stockholm to Helsinki - in a ferry, and then also drove (on "roads") from Finland thru Sweden to Norway. I wish we had owned the Fan-C-Dory back then (some fantastic areas) - but we were lucky to own the bus.
Dave - My recommendations for handholds follow. You can choose between what I call solid or rope systems. I use the five foot teak rails attached from the bottom of the side overhang (an inch inward). You can use SS screws from the bottom, or have quarter inch inserts put in the teak bottoms (between the loops) and drill a quarter inch hole in the roof and run a quarter inch by 20 SS bolt from underneath into the insert and snugged up, or drill holes from top to bottom of the railing through the roof and use a quarter inch pan head 20 SS bolt with SS washers and nut for securing. In the last system, you need to use a Forester bit to countersink enough to put in a teak plug for a nice, neat appearance on the top of the railing.
I have done both of the last two systems on two different 22' Dorys with complete success. You may wish to use SS railings instead of teak. I have found SS railings to be cold to the touch and in wet weather slippery.
Teak has that good non slip feeling.
Regarding the hand holds for the brow, I have employed two different systems. The first was using four (4) single loop teak rails spaced along the top and near the edge of the brow. This was helpful - far superior to grabbing the brow from the bottom where the overhand is too skimpy. That requires some fiddling to get the bases to follow the contour and bear evenly.
But on my second 22' I decided that I needed the whole enchilada. Remember that I turn 75 this July and lack the balance and agility of many of you youngsters. Don't worry, you will find out in time what I'm talking about.
Anyway, my second dory employed the rope system, and it is utterly superior to the solid hand rail. I decided to run a three quarter inch nylon rope (with a soft lay) around the perimeter How to do that? Get a piece of white oak board 3x2x10 inches. Drill a quarter inch hole (I used five (5) support columns meaning I needed five holes spaced correctly. Using the pre-drilled holes as a guide, use a two inch hole saw and cut out a hole (five times) It is best to clamp the oak board solidly when doing this.
A good drill press is most helpful doing this. Carefully pry out the now round blocks of white oak which all have a nice centered hole.
Place the blocks where you want them to go on your brow (perhaps at the painted edge) scribe where you want to drill a quarter inch hole into the brow. Use the old German carpenter method of measure twice drill once with each hole.
Now take five (5) SS eye bolts (1/4 by 20) three inches long , push the eye bolts down through the oak columns and brow, and snug up with the appropriate washers and nylock nuts. I make neoprene washers to fit under the round oak columns to protect the brow.
Next, take your nice soft nylon rope, thread it through the eyelets and secure both ends. You now have something to instantly grab and easy on the hands. The rope is elevated enough so you can slide your fingers over or under, depending on your situation.
If you want to maintain the teak decor, stain the white oak columns with dark penetrating walnut stain quickly followed by penetrating red oak stain. Rub off the excess, let dry and put on a good spar varnish, etc.
Sorry for this lengthy explanation. No, I don't have pictures to put on the net. Am not that techy yet.
Opps! It is a forstner bit not forester. John
John,
Now that is a very cool way to solve the handhold problem. Thanks for the clear explanation. :thup
Pat
Thanks John,
That last method sounds like a really neat way to do the job, I guess you could continue the runs aft along the edge of the roof. I already have my "grab" bars though, so guess it will be SS on Fan-C-Dory. We don't suffer much from cold, so we'll probably be OK.
Come on Al, tell us the history of those moose horns.
John, here's a picture of the historic MOOSE that plied Rainy Lake 100 years ago:
We liked the name as it suits both the C-Dory and our style. The antlers were added as a bit of personal expression. And I can't tell you how many nice people we have met because of them, primarily in NW Ontario where moose hunting is practically a religion.
Best regards,
Al
Kool Moose, if you squint it does kinda have a C-Doryish look !!
I think, since there are no moose in East Texas, that a lot of folks must be religiously hunting them here also. There's ALWAYS some in Wally World dressed in Camo !
Al - Great picture! I guess that makes yours mini moose. The next stop is google to find out more about Rainy Lake. Didn't realize it would be big enough for a boat that size. Wouldn't it be fun to build one like that?
Here in the wild west a steamboat even larger was built on the shores of Yellowstone Lake as an excursion boat. Its ribs and boiler parts can still be seen on the east side of Stevenson Island. Is the ice still on Rainy?
Take care. John
We had a record ice out this year, John, April 10th which is a month earlier than average.
Rainy is about 75 miles long, north arm to Kettle Falls on the east end. Several boat of the vintage of the historic Moose were known to have been run over Kettle Falls, before the dam obviously, on bets for bottles of whiskey. That's about a 10' drop. Don't know as I'd care to try that.
Al
