Hand rails
BBlalock
Jan 31, 2017
156
2013
25 Cruiser
Finale
I want to install hand rails on Finale's (25') cabin top and I want something like those on the cabin in the cockpit. Any suggestions of what from where? :smiled
I added hand rails on the eyebrow at the front corners like a number of other people.
I also added 36" rails on the aft cabin top (fore/aft at the outside edge). These make getting up on to the side walks from the cockpit and back down a lot easier. You don't have to try and reach the stock cabin top rails that are at the sides of the high top.
These rails are also handy when holding or hand maneuvering the boat at a dock (C-Dory's do sit kind of low for most docks, at least in my area). Like others have found, sometimes the boarding area of our boat is the cabin roof (depending on the dock and the tide).
I put these 18" hand railings on the side of the top--as described by Ssbol, and also at a diagonal on the front overhand. I prefer the type which have a 1/4" threaded stud in the center of the point where the fasteners go thru the roof, rather than a flange as in the defender example above. I got mine at West Marine.
I have put these type of railings on each of the 4 C Dory's I have owned. Very handy.
Thanks for the responses. I will get this project done very soon. I'm 6'3" and reaching out from under the bimini for the handrail gets to be a pain. But, many of you already know that.
There's two more places a hand rail may be of great benefit:
1. I placed 10-12 inch grab rails on either side of the cabin doorway mounted on the flat down-turned lip of the cabin top to get a very secure handle when stepping down into the cockpit from the gunnel. This is a much better position for a handle when coming down into the cockpit. The factory ones on the outside edge of the bulkhead are better when going up to the gunnel, but not down. These won't be of great value there when you have a bimini top up blocking their access, but otherwise there of great value. Also, in really rough weather, they help when getting forward into and through the doorway from the cockpit. (Overhead handles, like the optional ones inside.)
2. I also placed 18 inch hand rails on either side of the forward cabin trunk top for secure handles when going forward on the gunnel to the bow rail and bowsprit. There' a "no man's land" without a safe hold from the handrail added to the brow till you get fully forward without this added rail set. No problem in calm or moderate weather, but if the bow is heaving and you have to go forward to tend the anchor, etc., there's about two steps you have to take without any handhold support. You can always come up through the hatch in the trunk, but then you stand the chance of putting a wave full of water into your sleeping bag/clothes/ nightly companion/whatever.
Maybe one of both of these may seem extreme to the nimble younger C-Brats, but as you get older you need all the help you can get with your limited strength and mobility.
In either case, the extra support might just save you from injury, an unanticipated swim, or even your life.
Good Luck!
Stay on board however you can......................!
Joe. :teeth :thup
For the 25 two more places for a grab rail. One is the forward cabin bulkhead as a crash bar for the "navigator" to hang onto, when facing forward in the front dinette seat. The second is in front of the galley--that works well as a towel rack + gives a hand hold for the cook, if a boat "wakes" you when cooking...
Another place on a 25 for a grab rail is in the head. Otherwise folks will grab for the door handle if they loose their balance. We have one on the left side when sitting on the "throne". Some brats put them on both sides of the door.
Have fun with your projects....Tom
Following this discussion, I'm thinking we could well use a thread entitled "Safety and Convenience Modifications to C-Dorys for Senior Skippers and Crews". What do you think?
Joe. :teeth :thup
Besides the ones mentioned, thinking I was going to keep my 26 Venture a long
long time, I added a grab rail in the head. Of course, I don't need it now, but one
never knows when the future will become now.
It's slippery in there showering and a little upper body help when disengaging the
throne gets you back in action in a blink.
Aye.
Grandma used to say, "Think a head."
I was thinking of putting a small hand rail above the entry to the berth. It'd make getting in and out a little easier (at least the way I get out).
We also had been talking about that. But trying to figure the best place. I try and grab the hatch rail, esp. if it is open. We have Eagle Creek pack cubes suspended from the ceiling for clothes--but a handle could fit between. I am thinking a small handle.
Also we have a small handle to put in the splash well to help boating from the ladder.
Well went to WM today and got the 2 18" rails. I wanted something to go between the rail and gel coat and they recommended I go to AutoZone and get gasket material and cut it. I got a piece of that but not sure it is what I want to use. Any suggestions from anyone?
I use butyl tape to bed hand rails. It's not messy and no leaks on any of my railings.
Did anyone use a backing board when adding their hand rails or just fender washers? What size washers did you use? Thanks.
Depends on where you are installing them.
If you are putting the hand rails thru the outer lip, so they can be grabbed as you go forward from the cockpit--then only a plain washer--I believe they were 1/4". The hand rails on the cabin just outside of the raised top--fender washers. Use the diameter of the bolt welded to the bottom of SS rails, or thru teak as your guide.
In my 24, the hand rail bolts go thru to a rack on the ceiling made of wood which holds life jackets, and the camper back side curtains. So they go thru wood. In this case a standard washer is used.
Looking to install 12” handrails on the eyebrow and 18” handrails on the aft cabin top (outter edge). Thanks.
For those you are going thru about 1/4" thick fiberglass. There is not a lot of room under there--it is thru the outer lip, outside the cabin. Thus we just use a plain washer. That is plenty strong.
You will enjoy more security going forward, or even docking.
