Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,897
- Reaction score
- 239
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
As san juanderer noted, few of the LiFePO4 batteries are rated for engine start--and thus the engine, and other accessories can easily continue working. The other issue is that it is very rare for a BMS (external or internal) to shut down a battery. One could use the same argument for a fuse or battery switch failing with traditional FL:A batteries. In fact that is far more likely to happen in John's scenario than a BMS shutting down the Li bank.
Also we carry a jump start kit (greater use was for powering the inflatable dinghy pump, or charging I pads etc.).
I would agree that for the average boater I would not recommend the LiFePO4 batteries. If you are planning on keeping and using the boat for more than 5 years, is the point where the Li become justified.
There are many boats where the weight can be an issue and greater power density is necessary. For example bass boats and the trolling motors.
Certainly if one is contemplating use of the LiFePO4, read as much as possible. We followed one of the early RV adaptors who had 10 years of experience, mostly off grid, as an all electric coach using the LiFePO4 batteries for house.
Also the cost of higher quality LiFe batteries has been falling, and now is only 2x that of a quality AGM battery. Be careful about what brand you choose.
Will Prowse on teardown of several batteries.. This and a google search will find many articles by Will Prowse. They are somewhat RV and solar power oriented, but those applications are also very appropriate for our boats.
