Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 16
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
One note on the Dickinson Newport diesel is that it specifies a minimum of 4' of chimney. I noticed this because I was eyeing up the Sigmar 100 (similar small diesel bulkhead heater - I've used a larger Sigmar in the past on a sailboat and liked it) and noticed the same requirement. I can't see any practical way to get that much chimney with the stove in the "usual" counter-top location. At least, not without quite a bit of chimney pipe above the boat, which seems undesirable.
I did see that the propane P9000 only requires (IIRC) 28" of chimney, and I imagine the diesel/kerosene heaters with the really small chimney pipe (cozy cabin, maybe Taylors) may require less as well (although I have not looked them up).
I did see one stove installation in a C-Dory album (I forget which boat, but it was one of the 22's with the wood-grain cabinetry) wherein they had "given up" the cabinet under the sink and put the heater there (albeit it was the P9000 with its insulated chimney pipe; would probably be trickier with a "hot" pipe).
