Larry – click on Start then Run and type msconfig in the window and click OK
The System configuration window will open with seven tabs at the top. Click on the startup tab.
Here you will see a list of most programs starting automatically when windows starts. Here and throughout this post I refer to programs or services as programs.
Expand the command column and location column so you can see all text in them. Sometimes the name will tell you what the program is. Un-check those items you don’t want starting automatically then restart the computer and try it. If you don’t know what the program is, you can post the command line here and I will tell you what it is and does. You can experiment by un-checking an item to see what happens, but you will have to restart the computer each time. If it is something you find you want to start automatically, just re-check the item and restart.
If you have a lot of items listed, more than eight to ten, I would say you have too much starting in the background. I have three on my XP Machine. The one you do not want to stop is your antivirus program.
Once you determine the programs you don’t want to start in the background you should stop them other than here. Each program usually has a way of stopping it but it may take hours to figure out, so the best way is to delete them from your startup folder and registry. The location column will tell you where to go to delete its startup command line. While the System Configuration command will stop them, it is not the proper way to do it. It is OK for testing but should not be used to permanently stop them.
If you don’t know how to edit your registry let me know and I can post easy to follow directions for you.
The Services tab at the top of the Configuration window will show the services that are running. If you want to stop some of the un-necessary services let me know and I can help here also. I tweaked my XP machine around three years ago and it has never ever crashed and will startup in just over 30 seconds and is fast.
Two of the biggest resource hogs are Apple and Adobe products. Both think if you ever want to use their programs, it should always run in the background. Both can be stopped, but if they are updated an auto start line will be added again and I have had some of their applications add an auto start line every time you use it.
If you need more detailed help let me know.
_______
