Les Lampman
- Joined
- Oct 30, 2003
- Messages
- 779
- Reaction score
- 1
Hey all,
Well here goes...since y'all are bantering my name around! :wink So for Work Release and Others...
I've been aboard I don't how many CD22's, I know lots of folks that have them and I've rigged so many I've lost count. I've yet to meet an owner with a 4-stroke on the transom (of any make or model) that didn't just love his/her boat. It's darn near impossible to make a bad choice anywhere in the 75 to 100 hp range in any combination.
There's no reason to go to the Honda BF50's (over the 40's) unless you want them. They don't do much for the boat except add about 3 knots to the top end; a speed that's rarely used on most CD22's. On the other hand, there's no reason not to get the BF50's if they're your desire; there's no particular downside to them other than the extra loot. Put what makes you smile back there...after all it's a pleasure boat! :teeth
My personal preference is for the 40's; I like saving the extra money and I feel their performance is more closely matched to the CD22's characteristics. For instance, a very common cruise speed is in the upper teens; that puts the twins just at or under 4,000 rpm. The BF40 develops its peak torque at 3500 rpm; the BF50 at 4500 rpm. If we're at 4000 rpm pushing up the backside of a wave, as the engine rpm drops (from the additional load), on the BF40's the rpm is dropping toward peak torque and away from peak torque on the BF50's. In essence you're a bit on the 'backside' of the power band on the 50's and have to 'catch up'; the BF40's are ready to pull at that rpm.
NOTE: this is subtle stuff; for me it's a matter of optimizing the performance of the boat for the owner and the boat's intended use. So, if the boat's intended use is primarily light loads and higher speeds (maybe it lives on a lake) I'd happily recommend the 50's. It's also about not recommending a more expensive solution just for the heck of it; if you want it go for it. Most folks would never know the difference between running the twin 40's versus the twin 50's until they have lots of hours with each and even then I doubt that the comments would be negative either way. My philosophy is why pay for more then you need...unless you want it; then it makes perfect sense to go with the bigger engines. Nothing's worse than wishing you had made a different choice every time you go out in the boat.
I particularly like the choices in the Suzuki/Johnson line up at the moment and I'm a confirmed Honda lover! The advantages for the CD22 are that they have much better alternators than the Honda's (significantly; which is really nice when you're charging batteries after running lights, the Wallas, inverters, the stereo, etc) and they have EFI (I've not had too much trouble with Honda carbs but there's no denying it's awfully nice to just turn the key and start). A pair of Suzuki 40/50's (which I understand the factory now has) would be a good choice but I particularly like the 90 hp choice as it's a 1950cc engine (350cc more than the Honda 90...more torque and load moving capacity) and has a BIG alternator.
There's absolutely nothing wrong with a Yamaha either but the factory doesn't have them. And in the case of the F75/90 they're pretty much the same as the Honda BF75/90...4-cylinder, 4-carb, etc.
And yes, having twins on the CD22 does offer more maneuverability than a single; the question is how much more do you need than the single offers? This is a tough question. I've never been in a situation with a single that having twins would make significantly better. More convenient at times yes; but less convenient at others. I certainly wouldn't make the choice solely based on maneuverability. Sometimes KISS is good.
There isn't enough torque from the two small BF40/50 props to amount to anything when it comes to handling the boat with twins. If you absolutely nail the throttles with twins it still will not induce a torque reaction...it just ain't there. Counter-rotation just isn't necessary. A normal cruise prop going in the forward direction is more efficient than the same prop in reverse; this has more effect than torque steer when maneuvering the twins. With the wheel centered the boat will turn more to the forward direction and away from the motor in forward gear with the throttles at idle; it takes just a bit of throttle on the reversed engine to get a centered spin.
This is a bit of a non-issue since any wind will affect the CD22 a lot more than the props do as it slides quite easily.
Ok, as much as I'd like to finish this novel I've got to go to work (groan!). Later.
