Active member
- Joined
- Nov 21, 2004
- Messages
- 5,934
- Reaction score
- 4
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Meant to be
All,
Below is a copy of a question I sent to Les at EQ. I'm reposting part of it here since I'm desperate to get some help/ideas on this.
I have a problem with one of my twin 40's. Yesterday, I started getting an alarm - a loud beeping noise like the temperature indicator. The temp indicator red light is not on, I'm just getting the alarm. The engine is peeing normally (impeller was replaced less than 50 hours ago), to my hand the temp of the exiting water feels the same as the other engine. The water intakes are clear. The alarm is only on while the boat is in gear and operating above 2300 (or so RPM). When it's out of gear, I can run the RPM up to 4500 with the fast idle lever with no alarm. The speed is not limited and the engine appears to be operating normally - e.g. I get reasonable speed, it pees, the oil pressure is fine, the pee stream seems normal temp, the engine itself seems normal temp. I talked to Dusty briefly on the phone and he suggested that maybe the thermostat is shot.
What do you think the problem is likely to be?
Thanks in advance for any help you can offer.
Best,
Roger Bumgarner (SeaDNA).
Best,
